Date/Time: Mon, 24 Feb 2025 21:25:53 +0000
Hollow Down Candles
View Count: 630
[2021-03-24 03:00:24] |
User202883 - Posts: 24 |
I'd like to have a normal fill on up candles (bullish) and no fill - hollow - down candles (bearish). How can I do this? Thanks!
[2021-03-24 13:47:51] |
John - SC Support - Posts: 38146 |
One way to do this would be to use the Spreadsheet Formula (Bar) study and put in formulas for each item as follows: - Open: =IF(O < C, O, 0) - High: =IF(O < C, H, 0) - Low: =IF(O < C, L, 0) - Close:=IF(O < C, C, 0) Makes sure the Spreadsheet Formula is set to Region 1, and set the Subgraph Graph Draw Type to Candlestick Bars. Then set your Chart >> Graph Draw Type to Candlestick Hollow. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
