Date/Time: Fri, 02 Oct 2026 13:26:16 +0000
Pulling and Stacking Alert
View Count: 1888
| [2021-03-23 22:20:23] |
| User580470 - Posts: 8 |
Hi, is there way to put an alert on the "BID/Ask Market Depth Pulling/Stacking". For example, I like to be alerted when there's more than 100 contracts added on either the bid side or ask side. Thank you, |
| [2021-03-24 13:24:19] |
| John - SC Support - Posts: 48086 |
There is not a way to do this using the built-in tools. It can be developed using ACSIL using this function: ACSIL Interface Members - Functions: sc.GetBidMarketDepthStackPullValueAtPrice() For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
