Date/Time: Mon, 24 Feb 2025 21:09:50 +0000
How to view SierraChart on mobile device?
View Count: 2336
[2021-03-23 21:10:23] |
User71961 - Posts: 144 |
is there any way to view a chart from my running SC instance onto a mobile device? Perhaps just streaming to a webpage?
[2021-03-23 21:55:22] |
John - SC Support - Posts: 38146 |
If you are using the Sierra Chart Order Routing Service, then there is a Web Portal to be able to look at and adjust orders. You are not using this service. Otherwise, there is no built-in method to view Sierra Chart on a mobile device. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
