Date/Time: Mon, 24 Feb 2025 21:04:16 +0000
Account Help | Cannot connect to Transact WS | Urgent
View Count: 772
[2021-03-23 18:30:47] |
User800328 - Posts: 50 |
Hello, I am not able to connect to Transact WS Trading. All was well till this morning, but then there was space issue. I cleared up some files and then when I relaunched Sierra Chart, it said I cannot connect to Transact WS Trading. I have verified with Transact and they say everything is fine from their end. Please help me urgently. Here is the screen shot of error message I am getting. |
[2021-03-23 18:56:27] |
John - SC Support - Posts: 38146 |
It looks like you may have accidentally deleted your Accounts4.config file. It is not a problem. Just go to File >> Data/Trade Service Settings and enter your TransAct credentials on that page. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-23 19:01:17] |
I have but its still not taking it. And my username and password for Transact are correct too. Still the same error.
Date Time Of Last Edit: 2021-03-23 19:02:31
[2021-03-23 19:26:19] |
Called and talked with customer. He was missing the information in the "Account Number" field.
[2021-03-23 19:38:55] |
Done, thanks for the help.
