Date/Time: Mon, 24 Feb 2025 19:22:58 +0000
getting set up
View Count: 420
[2021-03-23 15:55:51] |
BRENDAN T - Posts: 1 |
its much to difficult to set up charts / system without verbal support. It's a mind field trying to navigate the instructions. I have set up the account. What do i need to do next .... what agreements need to be completed. where do i find them. Please help this new potential customer. thanks, Brendan
[2021-03-23 16:25:23] |
John - SC Support - Posts: 38146 |
Follow through the instructions here to get started: https://www.sierrachart.com/index.php?page=doc/GettingStarted.php#ConnectingtoData Keep in mind that you have access to the Delayed Streaming data for the CME Group and EUREX. Start working with that data and learning the system, then if you need Real-Time data, you can add that later. Refer to the following: Delayed Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
