Date/Time: Mon, 06 Jul 2026 05:43:33 +0000
OpenGL and GDI drawing question.
View Count: 975
| [2021-03-23 11:32:31] |
| GravisHTG - Posts: 321 |
I brought Gombang from Gomicators because I really like it. Unfortunately , It does not work when I have openGL unable because it use GDI drawing. Is their a way to enable open GL for that ? Thanks in advance. |
| [2021-03-23 14:41:21] |
| John - SC Support - Posts: 47017 |
You would have to ask the makers of Gomicators that question.
| [2021-03-23 15:10:03] |
OK , I ask them an they said it is because they do not have access to your OPEN GL platform. So they cant make it work with openGL enable. Is that right ? Date Time Of Last Edit: 2021-03-23 15:10:23
| [2021-03-23 15:15:22] |
Yes that is correct.
| [2021-03-24 18:10:14] |
| binaryduke - Posts: 387 |
Can you provide any recommendations for developers looking to use GDI drawing on how to best accommodate GDI and Sierra Chart's OpenGL support?
