Date/Time: Mon, 25 Nov 2024 18:50:02 +0000
Custom study
View Count: 1151
[2014-03-04 09:20:44]
User41689 - Posts: 8
Is it possible to create the following study for example, to add as a line onto the main chart, or as a value to display on the chart?
(POC-WVAP)/SD
[2014-03-05 14:24:07]
Anyone would be able if it is possible to create a custom study that uses other studies or parts/elements of other studies together?
[2014-03-05 16:13:02]
This can be done using the existing studies:
TPO or Volume Value Area Lines
Volume Weighted Average Price
And doing these calculations using the arithmetic studies found here:
https://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s227 (Study Subgraphs Difference)
