Date/Time: Mon, 24 Feb 2025 19:38:12 +0000
Barchart intraday stock/etf data (through Sierra) is not split adjusted?
View Count: 719
[2021-03-22 22:41:30]
WheresMoney - Posts: 62
For TQQQ
"TQQQ's 6th split took place on January 21, 2021. This was a 2 for 1 split"
This shows up correctly for a daily bar chart. But there is a gap in the intraday minute chart. I am using "sierra chart exchange data feed (250 sym)" which I believe is provided by Barchart.
Am I doing something wrong or is the data really not split adjusted? This is a big problem.
I have already done "The easiest way to adjust for a split is to download all the data for the symbol again rather than using the stock split function documented here. To do this, go to the chart and select Edit >> Delete All Data And Download". This didn't help
Date Time Of Last Edit: 2021-03-22 23:40:38
imagetqqq.png / V - Attached On 2021-03-22 22:40:55 UTC - Size: 26.83 KB - 207 views
[2021-03-23 00:34:12]
Sierra Chart - Max - Posts: 5793
We have reviewed the chart on our end, please follow the instructions here for the chart. After the refresh you will get the correct data.
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart.
Sierra Chart Support
Date Time Of Last Edit: 2021-03-23 00:35:00
