Date/Time: Mon, 24 Feb 2025 19:19:09 +0000
Setting up trading account -- CQG credentials?
View Count: 739
[2021-03-22 20:47:18] |
jb2294 - Posts: 14 |
Hello, After recovering, I would like to re-establish my trading account on SC. I have already made the payment for a month right now for package 11, and am looking to activate Denali Data Feed exchange for this: CME with Market Depth for nonprofessional Trading accounts. However, I am a bit confused on how I need to establish connection with SC and AMP futures account #*****. In the past when I first created both accounts, SC and AMP made the connection automatically. This time, I was given CQG live trading credentials to manually establish connection. Did I mess up? I believe I used SC ordering routing previously. Should I have selected the option "DISABLE ALL EXCHANGE DATA" if I were to use SC's ordering routing? I selected "SC - Denali - CQG (No data - ordering routing ONLY)" option this time, and this might have been a blunder. Thank you for your help in advance. Date Time Of Last Edit: 2021-03-22 21:02:11
[2021-03-22 21:16:48] |
John - SC Support - Posts: 38146 |
You are fine. To connect Sierra Chart to CQG, follow these instructions: CQG Trading Platform Service: Setup Instructions Then follow these instructions to make sure you are properly connected to the Denali Exchange Data Feed: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services And finally, open your Chartbooks and select Edit >> Translate Symbols to Current Service to update the symbols to the CQG symbols. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
