Date/Time: Sat, 01 Mar 2025 01:36:44 +0000
What is "Use Market Data Direct From Pirmary Server"?
View Count: 847
[2021-03-22 19:09:05] |
maxima120 - Posts: 144 |
when i configure SC to use DTC - Sub Instance, there is setting "Use Market Data Direct From Pirmary Server" - I cant find anything in the docs.. What is it for and how to use it?
[2021-03-23 10:35:23] |
This means the market data will come from the primary remote source rather than from the Sierra Chart DTC server the DTC sub instance is connected to. So for example if you use the symbol EURUSD the data would come from one of the Sierra Chart remote data servers and not from your own Sierra Chart server instance. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-09-12 06:09:10] |
GravisHTG - Posts: 306 |
is this more reliable ? i have 15 instance.
[2021-09-13 10:06:29] |
No, it is definitely not more reliable and we do not recommend using it.
