Date/Time: Mon, 24 Feb 2025 19:04:40 +0000
Why Rithmic is faster then Denali?
View Count: 1744
[2021-03-22 18:07:46]
User491299 - Posts: 26
Hello. Today I decided to use Denali datafeed during my trading (DOM trading) and found that it is a bit slow to my filling. It is irrelevant to people who don`t use the DOM to trade but I found that there is a big difference between Rithmic and Denali. I run up two SIERRA applications and compared two datafeed with T&S and found that Rithmic is faster you can identify its visually. Both update intervals are 10ms. I tried to play with SC server settings but nothing helps. Could you recommend any solution to make it fast as Rithmic? Thank you a lot.
Date Time Of Last Edit: 2021-03-22 18:08:27
imageRithmic vs Denali.png / V - Attached On 2021-03-22 18:08:22 UTC - Size: 35.38 KB - 303 views
[2021-03-22 18:28:46]
You cannot tell the speed by the timestamps since with Rithmic Sierra Chart only timestamps to the second and not the millisecond. And there are also settings which control the speed:
Prices / Data Falling Behind: 4.12 - Sierra Chart Exchange Data Feeds
Date Time Of Last Edit: 2021-03-22 19:06:09
