Date/Time: Mon, 24 Feb 2025 19:09:25 +0000
AMP account and Denali data and routing
View Count: 576
[2021-03-22 15:39:01]
Stefano Corsi - Posts: 4
Hi I already have an account with AMP and I use it with Rithmic I want use AMP with Sierra and Denali data and routing
How can I proceed ?
[2021-03-22 18:47:19]
John - SC Support - Posts: 38146
In order to use the Sierra Chart Order Routing Service you would need to change brokers. AMP no longer supports this service. Refer to the information at the following link including a partial list of brokers at Step #2 of the Setup Instructions:
Sierra Chart / Trading Technologies Futures Order Routing Service
If you want to stay with AMP, then you can continue to use Rithmic for Order Routing and use the Denali Exchange Data Feed. Just be aware that we do not give any Technical Support for Rithmic. You would also need to install the following files for use with Rithmic:
Rithmic Bridge Files
And then you would setup the Denali Exchange Data Feed following these instructions:
