Date/Time: Mon, 24 Feb 2025 19:33:12 +0000
Service Package Change / Order Routing / New Denali Symbols
View Count: 838
[2021-03-22 15:22:57]
User371906 - Posts: 141
Good evening,
I have a futures account with AMP and would like to have Denali Feed data but want my order routing to be via CQG.
Do I need to inform you that my order routing will be via CQG or my AMP broker?
I will set Service Package to 10 - Standard + Denali Data Feed - 36 USD / Month.
How to select new symbols from Denali as they will be different that AMP symbols?
Please let me know.
Thank You
G
[2021-03-22 18:26:04]
John - SC Support - Posts: 38146
AMP, as your broker, would definitely need to know that you would want to use CQG for your Order Routing. They will be the ones that set you up with CQG.
Once you have the CQG information from AMP, then you will find these instructions in order to connect your Sierra Chart to CQG:
CQG Trading Platform Service: Setup Instructions
After you setup CQG, then open your Chartbooks and select Edit >> Translate Symbols to Current Service. This will convert the symbols to CQG symbols.
[2021-03-22 20:23:28]
John,
Thank you for reply.
One last question, can I continue to use the CQG for both data feed and order routing and sign up for the Standard package $26 monthly? Or with new changes I need to change to Denali for data feed?
Regards,
[2021-03-22 21:06:56]
You can continue to use the CQG data for both data feed and order routing and just use the Standard Package 3 from Sierra Chart for $26.00 USD monthly.
We certainly do recommend using our Denali Exchange Data Feed, especially in terms of historical data, but it is not a requirement. For more information about the Denali Exchange Data Feed, refer to the following:
[2021-03-23 09:34:57]
If you are trading EUREX you will need to use the Denali Exchange Data Feed no matter what external trading service you are using.
[2021-03-23 10:56:42]
Thank You!
