Date/Time: Mon, 24 Feb 2025 22:38:04 +0000
Historical Market Depth
View Count: 663
[2021-03-22 13:14:52]
User852559 - Posts: 40
Historical market depth data is not automatically downloading for me in versions past 2238. In these versions I have to manually scroll back and select "Download Depth Data from Date/Time" option in right click shortcut menu. Please advise.
[2021-03-22 13:41:09]
Before you expect the problem to occur, clear the Message Log:
And then when the historical market depth data does not download, provide the Message Log by following these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
And tell us the symbol of the chart.
Date Time Of Last Edit: 2021-03-22 13:41:29
[2021-03-23 12:51:06]
I sent the log for analysis through SC.
[2021-03-25 19:20:35]
Just checking if you were able to review this log. Thanks.
[2021-03-26 06:30:06]
Yes we have had a look. Make sure this option is enabled.:
https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#SupportDownloadingHistoricalMarketDepthData
[2021-03-26 07:04:57]
It is enabled on the main instance and all sub instances. The log that I sent was from an instance with the option enabled.
[2021-03-26 15:28:35]
On the main instance follow this procedure:
Reconnect to the data feed:
