Date/Time: Mon, 24 Feb 2025 19:26:09 +0000
not getting data feed on $tick
View Count: 423
[2021-03-22 08:58:49] |
Channas - Posts: 32 |
I would start using $tick but after I opened the chart realised not getting a live data feed. Is the symbol correct?
[2021-03-22 13:45:57] |
The symbol is correct. Open a separate chart for that symbol and refer to help topic 3: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
