Date/Time: Tue, 06 Oct 2026 02:55:05 +0000
[Programming Help] - How to set Price1 few ticks higher
View Count: 977
[2021-03-22 05:06:08]
User641030 - Posts: 13
I'm new to Sierra chart ascil programming. So apologies if this is already covered in your documentation.
I've reproduced a portion of the code that I'm having trouble with.
BuyOrder.OrderQuantity = 1;
BuyOrder.OrderType = SCT_ORDERTYPE_LIMIT;
BuyOrder.Price1 = sc.High[sc.Index] + 2 * sc.TickSize;
BuyOrder.TimeInForce = SCT_TIF_GOOD_TILL_CANCELED;
The BuyEntry price always defaults to sc.High of the current bar. I tried to hardcode a price but it ignores and takes sc.High[sc.Index] instead.
I'm running in sim mode. I've also set Target and Stop for the same order.
Appreciate any help!.
[2021-03-22 06:09:42]
Flipper_2 - Posts: 57
try
BuyOrder.Price1 = sc.High[sc.Index] + (2 * sc.TickSize);
[2021-03-22 08:45:58]
User907968 - Posts: 884
You are trying to submit a buy limit order above current price, in which case it will fill immediately at the current best ask.
The order types are explained here - Order Types
[2021-03-22 08:56:09]
Ha! Yes didn't notice that. So the order type should probably be,
BuyOrder.OrderType = SCT_ORDERTYPE_STOP;
If you want the order to trigger if it trades 2 ticks above the current high.
[2021-03-23 13:08:50]
Thanks a lot. Will try with the stop order type.
