Date/Time: Mon, 24 Feb 2025 19:11:14 +0000
Numbers bars coloring issue
View Count: 440
[2021-03-21 18:18:42]
User202883 - Posts: 24
Range 0 color does not appear in my numbers bars. I've attached some of my settings. Not sure what to do to get that color to appear. Thanks.
imageScreen Shot 2021-03-21 at 3.06.33 PM.png / V - Attached On 2021-03-21 18:12:24 UTC - Size: 105.93 KB - 198 views
imageScreen Shot 2021-03-21 at 3.04.06 PM.png / V - Attached On 2021-03-21 18:12:26 UTC - Size: 130.95 KB - 176 views
imageScreen Shot 2021-03-21 at 3.06.06 PM.png / V - Attached On 2021-03-21 18:12:33 UTC - Size: 154.44 KB - 193 views
[2021-03-22 15:32:06]
John - SC Support - Posts: 38146
It depends on what your Background Coloring Method is set to. We can only see that it is one of the Diagonal Dominant options. So, for instance, if you are using Background Coloring Based on Diagonal Dominant Side AskVol BidVol Percentage then there will never be a percentage less than 1, as it is displaying the Dominant side, which means it will always be at least 1.0. Refer to the information here:
Numbers Bars: Background Coloring Based on Diagonal Dominant Side AskVol BidVol Percentage
