Date/Time: Mon, 10 Mar 2025 16:10:14 +0000
Volume Profile Question
View Count: 770
[2021-03-21 17:01:12]
User402365 - Posts: 9
Hi! I've been able to set up a volume profile for each day on my 15 minute chart. The volume profile starts from 6:00 PM to 5:00 PM each day. Each day it is reflected from the left to the right. I'm trying to include a 7 day volume profile on the same chart but off to the far right reading from right to left. I don't want it to overlay the existing daily profiles but it does. It doesn't erase the daily volume profiles but since it overlays them it's difficult to read even if I make the 7 day vp a different color. Also, I'd like to be able to include the price at the value area high, low and poc of each day but can't seem to make that happen either. It will show for the current day only but not final numbers for previous days. Thanks so much for your help.
Date Time Of Last Edit: 2021-03-21 17:25:14
[2021-03-22 14:11:53]
Refer to:
Volume By Price Study: Right Aligning Volume Profiles with Space on Right Side of Chart
One way to do this is using these Volume by Price Input settings:
Volume By Price Study: Show Chart Values On Profile
Refer to the first Input linked to and the following ones.
[2022-04-02 17:32:27]
Hi! I currently have Denali but under Global Settings, Data/Trade Service Settings there is no option for Denali. I'm sure I'm just misunderstanding what I should be selecting here. I currently have selected CQG WebAPI. Is that what I should have selected? I want to be able to load continuous contract data in my tick charts. Thanks for your assistance.
[2022-04-04 14:34:17]
John - SC Support - Posts: 38530
If you are trading using CQG for your trading service, then you need to set your Data/Trade Service Settings for your CQG connection. Refer to the Setup Instructions here:
CQG Trading Platform Service: Setup Instructions
Sierra Chart is setup to allow our data to get into the system while you trade with your selected trading service. Therefore, all you need to do is have your data setup properly with us and then your system will take care of the rest. But, refer to the following for more information:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
But, we noticed that although you are on package 11, you do not have any exchanges active on the Denali Exchange Data Feed. If you are wanting data for the CME Group, then you will need to activate an exchange here:
https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges
