Date/Time: Mon, 24 Feb 2025 19:05:04 +0000
Extend the OHLC study line into forward columns?
View Count: 1039
[2021-03-21 02:41:09] |
58LesPaul - Posts: 429 |
Is there any way to extend the OHLC study lines into the forward column area where price hasn't populated yet? Thanks |
[2021-03-21 05:47:49] |
User90125 - Posts: 715 |
For each of the OHLC subgraphs, try changing the Displacment setting to the number of forward columns you want. Also make sure that you set the maximum number of forward columns that your chart will allow by using Chart Settings >>> Advance Settings >> Number of Forward Columns |
[2021-03-21 16:17:04] |
Depending upon exactly what you want to do, there are different ways of doing this. What specific study are you referring to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-21 20:08:01] |
Daily OHLC study but User212764 pointed me in the right direction. Is that the only way of doing this? Thanks And Thanks User212764 |
[2021-03-22 05:45:45] |
No prob. I figured that's what you were talking about. :) |
[2021-03-22 22:47:23] |
When I extend the Daily OHLC study with the displacement selection, it waits to change for the new high/low that many bars. So I have a vertical line from the old high/low to the new high/low not at 6pm but 6:10pm. Is there any way to extend the lines into the unpopulated forward columns without losing that same number of displacement columns on the other end of the chart? Also, Is there anyway to not get the vertical line when the lines change from one day to another? Thanks Date Time Of Last Edit: 2021-03-22 22:48:35
[2021-03-23 14:02:28] |
John - SC Support - Posts: 38146 |
The better way to do what you are wanting is to use the Study Subgraph Reference study and apply it 4 times to chart, once for each Open, High, Low and Close from the Daily OHLC study. Then set the Subgraph Draw Style for the Study Subgraph Reference to Line at Last Bar to Edge. Refer to the following: Study Subgraph Reference And refer to the following for the Draw Style: Chart Studies: Subgraphs Tab >> Draw Style To remove the connections between days, set the Draw Style for the Daily OHLC subgraphs to Dash. Refer to the following: Chart Studies: Dash (ACSIL: DRAWSTYLE_DASH) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
