Date/Time: Mon, 24 Feb 2025 19:13:23 +0000
Replay option
View Count: 496
[2021-03-20 23:59:05]
Sensei - Posts: 8
Hello, I am having issues with the replay option. When I click play on the replay the full bar for the time frame appears when I press play and does not replay. It used to work perfectly fine until a couple of days ago. I am not sure what option I changed.
[2021-03-23 09:17:45]
First thing to do is to go through the step-by-step instructions here:
Replaying Charts: Basic Chart Replay Instructions
To make sure you are doing everything correctly.
Date Time Of Last Edit: 2021-03-23 09:18:02
[2021-03-23 16:14:13]
Sensei - Posts: 8
figured it out. did not select replay charts with the same link number. That's why my overlay bars were not replaying.
