Date/Time: Mon, 25 Nov 2024 19:32:38 +0000
ask bid volume
View Count: 1232
[2014-03-03 19:04:58]
infpz - Posts: 826
best way to replicate this image? ask bid volume difference, but the only the individual cell, not the whole column, is colored based on the ABVD value.
image1234.png / V - Attached On 2014-03-03 19:04:45 UTC - Size: 56.98 KB - 394 views
[2014-03-03 19:46:52]
This can be done with the Numbers Bars study:
http://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php
With the Numbers Bars study you will need to set the Column 1 Numbers Bars Text to Ask Bid Volume Difference.
[2014-03-03 19:52:27]
infpz - Posts: 826
Yes, but in his chart, the positive numbers are all blue, and the negatives are red. On the numbers bars study without changing any other inputs (other than column 1 text), the field can be positive and still be red, or negative and still be green. Looking to fix that.
[2014-03-03 20:36:48]
You will need to set the Column 1 Background Coloring Method for the Numbers Bars column to Based On Ask Volume Bid Volume Difference Percentage:
https://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#AskVolBidVolDiffPercentage
Date Time Of Last Edit: 2014-03-03 20:38:47
