Date/Time: Mon, 24 Feb 2025 19:10:41 +0000
10 - Standard + Denali Data Feed
View Count: 640
[2021-03-20 20:55:24] |
User956467 - Posts: 30 |
After reading the "Notice: Transition to Direct Sierra Chart Billing For SC Accounts through Broker thread, I would appreciate a confirmation. I use AMP/CQG for live trading. The only symbols I use are for the: ES (current month F.US.EPM21) and NYSE Tick (TICK-NYSE). Do I need anything other than SC PKG 10 - Standard + Denali Data Feed $36? Thank you! |
[2021-03-22 14:59:24] |
John - SC Support - Posts: 38146 |
Looking at the services you were using previously and what you state above, you would need the following: - Sierra Chart Package 10: $36.00 per month - "Full CME Group for Non-Professionals" exchange: $3.25 per month We also see that you had the Sierra Chart Exchange Data Feed active and the "S&P Indices" exchange active. You do NOT need this for the TICK-NYSE (the TICK-NYSE is part of the Market Statistics from Sierra Chart). If you do not want the "S&P Indices" then you will need to also deactivate the Sierra Chart Exchange Data Feed, which is still active on your account. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
