Date/Time: Thu, 01 Oct 2026 07:23:23 +0000
Connecting my 2 AMP Futures accounts to my sierra account please.
View Count: 1029
| [2021-03-20 01:20:46] |
| theunknowntrader - Posts: 112 |
The issue is I have two AMP accounts with CQG, how can i add the second one? do i have to have a second instance?
| [2021-03-22 13:44:55] |
| John - SC Support - Posts: 48074 |
If both accounts are accessible through the same login for CQG, then you should have both accounts available within Sierra Chart. Refer to the following for how to select a specific account: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) If you can see them both as above, then you do not need a second instance. If, on the other hand, the above does not work, as your accounts are separate from one another, then you would want to have a second installation of Sierra Chart where each is accessing one of the accounts. Refer to the following: Using Multiple Data and Trading Services at the Same Time: Working with Multiple Trade Accounts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-03-22 15:01:48] |
Really it is best you ask your broker to put the two accounts on a single CQG Username.
