Date/Time: Mon, 24 Feb 2025 18:44:54 +0000
Non Professional Data Service
View Count: 688
[2021-03-19 22:58:13] |
User745741 - Posts: 3 |
Hello, I am a non professional and currently use Interactive Brokers but because their data feed is garbage as you know, I signed up for the Denali Exchange Data and CME Market Depth for non professionals. However, I do not want to have to log in once a month to my Interactive Brokers platform as this can be cumbersome or I may simply forget. I know there is the option to use Sierra Chart Order Routing Service but I do not see Interactive Brokers there as an option to add my account. I also see there is an option to enable the Allow Support for Sierra Chart Data Feeds, but after choosing this option and selecting Interactive Brokers under the Current Selected Service list, it reverts to the Interactive Brokers data feed, which is not what I want to use. |
[2021-03-20 00:46:50] |
The configuration that you should use is what is documented here: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services If you do not want to do live trading from Sierra Chart, you can just make sure that Trade >> Trade Simulation Mode On is enabled. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
