Date/Time: Mon, 24 Feb 2025 18:39:41 +0000
VAP Bar Percentage Comparison
View Count: 603
[2021-03-19 18:18:26]
quin6 - Posts: 22
First and foremost, you don't have to handfeed me the code I know that's annoying for you.
I'm looking to create an indicator that analyzes the weekly volume profile levels (bars) and plots horizontal lines whenever the ratio of volume between two bars is greater than a certain amount.
Kind of like peaks and valleys but more accurate.
Any idea on how to get started with this?
Thanks.
[2021-03-19 19:17:03]
John - SC Support - Posts: 38145
You would get the Volume At Price data using the following function:
ACSIL Interface Members - Functions: sc.GetVolumeAtPriceDataForStudyProfile()
And then you can use the following to draw the line:
ACSIL Interface Members - Functions: sc.AddLineUntilFutureIntersection()
