Date/Time: Sat, 04 Jul 2026 14:19:30 +0000
Denali datafeed
View Count: 1013
[2021-03-19 18:06:47]
User491299 - Posts: 26
Good day. I created "Account Support ticket" few days ago but still have no help. Will explain my problem here. I ordered Denali Data feed and I want to use it with my Rithmic Data (OneUP Funded acc. (MES Capital)). I did every step to connect it simultaneously with Rithmic but it doesn`t work. In my SC accont I can see that my verification of funded trading account has expired few months ago. Can acc. verification cause those problems? Need your help. Thank you.
[2021-03-19 19:13:45]
John - SC Support - Posts: 47017
Not having a verified trading account is definitely the reason you are not getting the Real-Time data. But, if you are properly connecting to Rithmic, then you should have been updating your trading account verification.
Are you currently connected to Rithmic? Are you always connected to Rithmic? Are you having any issues being connected to Rithmic?
If you are not having any trouble connecting to Rithmic then we would need to see your Message Log following these instructions:
Reconnect to the data feed:
[2021-03-19 19:32:19]
Yes, I am always connected to Rithmic. No problems with Rithmic connection.
[2021-03-19 19:32:25]
Software version: 2239 64-bit | 2021-03-19 21:29:54.900
OpenGL enabled | 2021-03-19 21:29:54.900
Primary Thread ID: 5224 | 2021-03-19 21:29:54.900
Usage end date: 2021-04-04 | 2021-03-19 21:29:54.900
Enabled for: Advanced Features 2. | 2021-03-19 21:29:54.900
Enabled for: Sierra Chart Historical Data Service. | 2021-03-19 21:29:54.900
Enabled for: Denali Real-Time Exchange Data Feed. | 2021-03-19 21:29:54.900
Enabled for: Delayed Denali Exchange Data Feed. | 2021-03-19 21:29:54.900
Enabled for exchange2: CME | 2021-03-19 21:29:54.900
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-03-19 21:29:54.900
Current selected Data/Trading service: Rithmic Trading | 2021-03-19 21:29:54.900
Custom symbol settings values: enabled | 2021-03-19 21:29:54.900
Chart Update Interval: 500 | 2021-03-19 21:29:54.900
Intraday Data Storage Time Unit: 0 | 2021-03-19 21:29:54.900
Time Zone: +02:00:00 (EET+02EEST+01,M3.5.0/03:00,M10.5.0/04:00) | 2021-03-19 21:29:54.900
2021-03-19 19:29:54 Local computer time in UTC | 2021-03-19 21:29:54.900
2021-03-19 21:29:54 Local computer time in SC Time Zone | 2021-03-19 21:29:54.900
2021-03-19 19:28:37 Server time in UTC | 2021-03-19 21:29:54.900
Local computer UTC time and Server UTC time difference: 2 seconds. | 2021-03-19 21:29:54.900
Program path: C:\SierraChart\ | 2021-03-19 21:29:54.900
Data Files path: C:\SierraChart\Data\ | 2021-03-19 21:29:54.900
OS Version Number: 10.0 | 2021-03-19 21:29:54.900
Locale Setting: C | 2021-03-19 21:29:54.900
DLLs: ETFISv3.dll, ETFISv3_64.dll, Smaug_SC_Library.dll, Smaug_SC_Library_2151_64.dll, Smaug_SC_Library_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll, zyp sierra free (2020).dll, zyp sierra free (2020)_64.dll, zyp sierra free.dll, zyp sierra free_64.dll | 2021-03-19 21:29:54.901
Allowed protected custom studies: Smaug_SC_Library, zyp_download_free | 2021-03-19 21:29:54.901
DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-03-19 21:30:07.081
DTC Client socket (1) | Closed. | 2021-03-19 21:30:07.081
Rithmic Trading | Port for executable: 58177 | 2021-03-19 21:31:04.746
Listening socket (0). Port 58177 | Closed. | 2021-03-19 21:31:04.746
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2021-03-19 21:31:04.747
Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2021-03-19 21:31:04.752
Rithmic Trading | Bridge process is running. | 2021-03-19 21:31:06.751
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58177 | 2021-03-19 21:31:06.751
DTC Client socket (1) | Creating socket. | 2021-03-19 21:31:06.751
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-03-19 21:31:06.752
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-03-19 21:31:06.752
Rithmic Trading | Network connection to server complete. | 2021-03-19 21:31:06.764
Rithmic Trading | Starting socket receive thread. | 2021-03-19 21:31:06.764
Rithmic Trading | Sending encoding request to server: Binary VLS. Compression: none | 2021-03-19 21:31:06.764
Rithmic Trading | Setting DTC encoding to Binary VLS | 2021-03-19 21:31:06.769
Rithmic Trading | Sending logon request message. | 2021-03-19 21:31:06.769
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2021-03-19 21:31:06.777
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2021-03-19 21:31:06.787
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital server. | 2021-03-19 21:31:06.787
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2021-03-19 21:31:08.282
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2021-03-19 21:31:08.424
Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2021-03-19 21:31:09.190
Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2021-03-19 21:31:09.338
Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2021-03-19 21:31:10.101
Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2021-03-19 21:31:10.245
Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2021-03-19 21:31:10.966
Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2021-03-19 21:31:11.102
Rithmic Trading | Received logon response. | 2021-03-19 21:31:11.776
Rithmic Trading | Server Name: SC DTC Bridge. | 2021-03-19 21:31:11.776
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2021-03-19 21:31:11.776
Rithmic Trading | Successfully connected. IB='MESCapital', Firm='MESCapital'. | 2021-03-19 21:31:11.776
Rithmic Trading | Trading is supported. | 2021-03-19 21:31:11.776
Rithmic Trading | Order cancel and replace is supported. | 2021-03-19 21:31:11.776
Rithmic Trading | OCO Orders supported. | 2021-03-19 21:31:11.776
Rithmic Trading | Connected to server complete. | 2021-03-19 21:31:11.776
Triggering next historical data download in queue. | 2021-03-19 21:31:11.777
Subscribing to symbol for symbol alert. ESZ0-CME | 2021-03-19 21:31:11.777
Rithmic Trading | Starting real-time market data updates for: ESZ0-CME. ID: 1 Service code: rithmic.trading | 2021-03-19 21:31:11.777
Rithmic Trading | Requesting security definition data for: ESZ0-CME. ID: 1 | 2021-03-19 21:31:11.777
Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2021-03-19 21:31:11.777
No download requests in the queue to start downloads for. | 2021-03-19 21:31:11.778
Rithmic Trading | Message from server: Received unknown message type from DTC client. Type = 603 | 2021-03-19 21:31:11.844
[2021-03-19 19:35:38]
The Rithmic account you are connecting to is not considered a live trading account which meets CME rules
Date Time Of Last Edit: 2021-03-19 19:35:51
[2021-03-19 19:43:23]
What should I do? Fund AMP acc. and complete verification and after that connect use my Rithmic? Thank you.
[2021-03-19 20:47:49]
You would need to check with MES Capital and see if your account also has Live Trading capability. If it does, then you would just need to connect to one of the Live Rithmic servers to validate your account.
If it does not, then you would need to have another trading account to validate for the CME Group. We recommend the following service:
Easy Solution to CME Funded Trading Account Requirement
