Date/Time: Mon, 24 Feb 2025 19:04:00 +0000
Spread Count
View Count: 494
[2021-03-19 16:39:17] |
User161806 - Posts: 18 |
Hi there, Hope you are keeping well. Wanted to see if you guys had a spreadcount box that you can move? Ideally, Id like to position it closer to my count down timer. Please see image posted. I can get the spread count in a the header but not in a box similar to the countdown time Would love to know how to achieve this feature. Thanks for your time. Josh |
![]() Attachment Deleted. |
[2021-03-19 16:52:58] |
John - SC Support - Posts: 38146 |
You can see the spread visually by using the option Chart >> Show Bid and Ask Lines. If you want the number displayed, then you would need to put together a few studies to do what you want. In particular, you would need the following: - Bid Ask Prices - Study Subgraphs Difference - Text Display for Study Refer to the following for Bid Ask Prices: Bid & Ask Prices Refer to the following for Study Subgraphs Difference: Study Subgraphs Subtract/Difference Refer to the following for Text Display for Study: Text Display For Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-20 04:10:07] |
Such a versatile platform. Thank you very much for your time John. Have a great weekend! Best regards, Josh |
[2021-03-23 00:40:06] |
Someone gave me this indicator Please use this as it might be useful for some of the other Sierra users :) |
Attachment Deleted. Private File |
