Date/Time: Mon, 24 Feb 2025 17:56:54 +0000
placing trades
View Count: 505
[2021-03-19 15:25:27]
User921512 - Posts: 8
When I try to place a live trade on sierra chart I am redirected to a sim account to place the trade. I recently switched to denali data and use AMP to facilitate my trades. I have verified with AMP that I'm set up to route trades through CQG. Not sure what is going on...
Nik
[2021-03-19 16:24:01]
John - SC Support - Posts: 38137
You have not setup your Sierra Chart to connect to CQG. You need to follow these Setup Instructions:
CQG Trading Platform Service: Setup Instructions
After you do the above, then you will need to open your Chartbooks and select Edit >> Translate Symbols to Current Service to change your symbols to CQG symbols.
[2021-03-19 16:46:00]
is my data through denali when i set this up or cqg?
[2021-03-19 17:09:22]
Your data will be from us (Sierra Chart) through our Denali Exchange Data Feed. For more information on getting the data from us when using a supported trading service, refer to the following:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
