Date/Time: Mon, 24 Feb 2025 18:08:44 +0000
denali account
View Count: 471
[2021-03-19 15:24:52]
Anapurna - Posts: 10
Hi, I'm still with AMP, sounds like my TT data feed got disabled by them which is the problem? I have a choice of CQG, and Rithmic with AMP (they still list TT). What would you recommend? Or a different brokerage?
[2021-03-19 16:20:51]
John - SC Support - Posts: 38138
We do not make recommendations on brokers. The only thing we can tell you is that the Sierra Chart Order Routing Service is still available through other brokers. You will find a partial list of brokers at Step #2 here:
https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions
If you stay with AMP, then you will want to use CQG for order routing as we do not offer any technical support for Rithmic.
If you do stay with AMP and use CQG, then you will need to follow the Setup Instructions at this link to connect Sierra Chart to CQG:
CQG Trading Platform Service: Setup Instructions
After that is done, you will need to open your Chartbooks and select Edit >> Translate Symbols to Current Service in order to update your symbols to CQG symbols.
