Date/Time: Mon, 24 Feb 2025 17:55:00 +0000
Custom Daily P/L Report
View Count: 549
[2021-03-19 14:39:48] |
User772499 - Posts: 48 |
I've tried to use the built in reports in SC via the Trade menu but can not get a report the way I'd like it to be. What I'd like is a flat to flat acct position report. I like to scale into trades so for example I enter with a 1 lot then add on 1, then exit both. This is one trade in my system. From the report for this trade I'd like to see: Total lot size traded (2) Short or Long Net trade P/L (without or with comm) Can reports be customized? Can spreadsheets be used somehow to run this daily report? Thanks you. |
[2021-03-19 15:04:31] |
John - SC Support - Posts: 38137 |
The options that are available are in the Edit menu for the Trade Activity Log. It sounds like you want to select the option Edit >> Flat to Flat Display for Trades List. Refer to the information here: Trade Activity Log: Trade Activity Data Editing Menu Commands (Trade >> Trade Activity Log) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-19 15:39:21] |
Great. Thanks. I'll check that out.
