Date/Time: Mon, 24 Feb 2025 22:07:58 +0000
Direct Order Routing
View Count: 996
[2021-03-19 06:13:18]
tobi - Posts: 351
I've been off trading for a while and want to restart again. Reading through the support board there has been a lot of writing about order routing issues with TT, CQG, AMP etc.
Please help me on the following questions:
1.
Is SC Futures Order Routing Service with Data still active and working as described here (routing through TT)?
Sierra Chart / Trading Technologies Futures Order Routing Service
2.
Would you recommend working with AMP (just as broker; SC and data directly from you/SC) or are there better alternatives?
3.
Does your order routing service (the current one and the new one you are working on) work with IB?
If yes, can you recommend using this combination (IB just for clearing; SC and data directly from you/SC)
Thank you for getting me back started.
[2021-03-19 13:43:09]
John - SC Support - Posts: 38146
1. The Sierra Chart Order Routing Service is still available. It is just no longer available through AMP. You will find a partial list of brokers that support the Sierra Chart Order Routing Service at Step #2 of the Setup Instructions here:
https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions
2. As noted above, you cannot use the Sierra Chart Order Routing Service with AMP. If you do use AMP, you would be using CQG for order routing. This is fine, although we do recommend getting the data from us, as you have stated you would.
3. The Sierra Chart Order Routing Service does not work with Interactive Brokers. They have their own order routing. Just like the above with AMP, we highly recommend using the Sierra Chart data in this combination.
[2021-03-19 13:54:17]
tobi - Posts: 351
And new Direct Order Routing you are currently working on, will this be working with AMP or (only) with the brokers from the list mentioned above?
[2021-03-19 14:21:02]
Yes we expect it will work with AMP when available.
[2021-03-20 05:46:26]
tobi - Posts: 351
For futures trading (CME and Eurex), which combination would be best from your point of few?
Sierra Chart and data in all cases completly from Sierra Chart.
Using
a. Interactive Broker's order routing
b. AMP with CQG order routing
c. Dorman (e.g.) with Sierra Chart order routing ?
Or doesn't it matter as long as data is from Sierra Chart?
Date Time Of Last Edit: 2021-03-20 05:55:37
[2021-03-22 13:50:23]
We are certainly going to recommend using the Sierra Chart Order Routing Service if you can, as that gives you the most capability for your trading. Just be sure you check to make sure that if you are trading EUREX that the broker does not charge extra for that capability.
Refer to the following for what is available with the Sierra Chart Order Routing:
[2021-03-23 16:56:52]
tobi - Posts: 351
Can you/anyone tell which broker from the list doesn't charge extra for EUREX (and has reasonable fees).
Date Time Of Last Edit: 2021-03-23 16:57:12
[2021-03-26 04:46:19]
tobi - Posts: 351
Any recommendations?
