Date/Time: Mon, 24 Feb 2025 18:00:14 +0000
Chartbooks questions
View Count: 907
[2021-03-18 17:25:29] |
franmadrid - Posts: 24 |
Hi John 1- is it possible use " global cursor" in diferents charts books. I have diferents chartbooks in diferents screens, but I want to track at the same time all chartbooks using the globalcursor, Is it possible? 2.-Can I use studyoverlay from other chartbooks or between chartbooks? 3.-Would be possible merge 2 chartbook in one with any tools ?? I have a lot of charts in two differents chartbooks with a lot of indicator and studyoveray ..could migrated easy in only one.? thanks |
[2021-03-18 20:22:47] |
John - SC Support - Posts: 38137 |
1. No, Global Cursor only works within a single chartbook. 2. No, study overlay only works within a single chartbook. 3. The only option is to Duplicate Chart to Chartbook. Refer to the following: Chart Menu: Duplicate Chart To Chartbook (Chart menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-19 17:52:26] |
thanks John, to do more easy my work .. 1.- Is it possible look in a particular chartbook look all the alert activate ? or look all alarm or alert activa in a particular charts to avoid having to enter all the indicators one by one. 2.- Can I look all dependencies in one chart book or particular charts? or I need to review all indicator ( all charts?) for example if my chat #2 have study overlay from chart #1 can I look in a list ? ( I am looking easy way to merge 2 chartsbooks in one) 3.- If I detach a chart from chartbook #2 can I keep one top over chartbook #1? In other word , can I detach from a particular chartbook to use in other chartbook? Thank for you time John. Let me know the link to learn to do it pls |
[2021-03-19 18:53:15] |
1. To view all the alerts for a Chartbook you would open the Alert Log. Refer to the following: Alerts Manager: Alerts Log You can also use the Study Summary to see where an alert would have occurred in a particular chart. Refer to the following: Study Summary Window: Setting Alerts and Alert Highlighting 2. We are not sure what is being asked here that is different from #1 above. 3. Yes, you can detach a chart from one chartbook and have it still be visible when you are in a different Chartbook. To do this, you would select Window >> Always Visible on the Detached Chart. Refer to the following: Window, CB and CW Menus: Window Always Visible (Window) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-19 19:56:43] |
last question John, Why my chartbook #1 rolled to the new contract and the #2 not? .. I will attach both setups. |
[2021-03-19 20:51:33] |
You would need to look at the first tab of the Chart Settings and see if one has the option for Automatically Rollover Futures Symbol and the other does not. If it is the way we think, you should have received a notification in the chart that did not automatically rollover that it needed to roll over. Let us know if you did not receive that message. Refer to the following: Chart Settings: Automatically Rollover Futures Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
