Date/Time: Mon, 24 Feb 2025 18:32:03 +0000
How to hide bid/ask size in chart DOM columns?
View Count: 773
[2021-03-18 16:54:37] |
WheresMoney - Posts: 62 |
See https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=49367 These charts are identical, but the lower chart shows bid/ask size in the chart dom. They are in the same chartbook. Using SC version 2239. How do I get rid of the bid/ask size in the lower chart and make it look like the top chart? Sorry about such a simple thing, but I just couldn't find the setting. Thanks! |
[2021-03-18 19:32:45] |
John - SC Support - Posts: 38144 |
You need to change your columns to be the "Sell Order" and "Buy Order" rather than the Size columns. Refer to the information here: Global Trade Settings Windows: Sell Order Column - Left/Center/Right Aligned For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
