Date/Time: Mon, 24 Feb 2025 19:13:05 +0000
Denali Data
View Count: 739
[2021-03-18 16:31:38] |
User600014 - Posts: 12 |
I currently have several months left on my package 5 subscription. I would like to downgrade to what was package 3 without the advanced features and add Denali real time level 1 data for CME and COMEX. How do I go about doing this? Thanks
[2021-03-18 18:58:23] |
John - SC Support - Posts: 38146 |
The first thing you do is change your package to Package 10. This is the Standard Package with the Denali Data Feed Fee. Then you will follow the Setup Instructions for the CME Group within the Denali Exchange Data Feed here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-22 22:36:45] |
I have 4 months left on my package 5. I no longer use the capability of package 5 and only require package 3(and not Denali). If I change to package 3 now and select for 6 months will the balance of my package 5 be applied to this renewal?
[2021-03-23 09:28:17] |
. If I change to package 3 now and select for 6 months will the balance of my package 5 be applied to this renewal? Yes.To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link. Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
