Date/Time: Mon, 10 Mar 2025 13:23:07 +0000
Trailing Percent of Profit
View Count: 902
[2021-03-18 14:42:12]
owendonk - Posts: 54
Is there a way to set a trailing stop that adjusts to percent of profit, let's say 80%? For example, buy 3940 and it's at 3950, stop should be 3948 (.8*10). If it goes 3960, the stop should be 3956 (.8*20).
[2021-03-18 15:40:31]
John - SC Support - Posts: 38516
You can use the Trade Management by Study study and then base it on another study or studies that calculate the profit. Refer to the following:
Attached Orders: Study Controlled Targets and Stops
And it may be easiest to use the Spreadsheet Study for Trading to calculate the profitability of the trade. Refer to the following:
Spreadsheet Systems, Alerts and Automated Trading
[2021-10-29 17:43:04]
JDCII2112 - Posts: 21
Hey Owendonk,
Did you get this to work?
Thanks.
[2021-10-29 17:45:39]
No
[2022-03-30 18:26:49]
User379468 - Posts: 508
Has anyone been able to set up something like this?
