Date/Time: Mon, 25 Nov 2024 19:30:01 +0000
How do you adjust room for Y axis figures.
View Count: 1173
[2014-03-03 16:01:53]
The Stealthy Trader - Posts: 185
Some of my indicators have results that go out multiple places..like 450,000 rather that 45.
I've noticed an annoying aspect with these charts being that if the number is large enough, you lose sight of the last couple of zeros. So, I have to go to great lengths to access the Indicator Value pop up box..
Is there a way to adjust how far from the right margin the Y Axis is?
This way 4,500,000 will be as easy to decipher as 450
Please advise..
J.
[2014-03-03 19:53:32]
The only way this can be done is to increase the number of decimal places with the Price Display Format in Chart >> Chart Settings. That will widen the right side Values Scale.
[2014-03-03 21:24:06]
Yup, that does it..thanks so much!
Would be great if you could apply this setting to specific sections of your window instead of across the board as although this is necessary for one of my indicators, it's not for the actual chart part..looks a bit awkward having .001 as an increment for the stock prices on my Y axis...
But it does help with the indicator section..
thanks again
