Date/Time: Mon, 24 Feb 2025 16:03:45 +0000
[Programming Help] - Simple Alert for "Wide Range Bar" study.
View Count: 586
[2021-03-18 09:52:29] |
artmaan - Posts: 26 |
Hello, what is the best way to create a simple sound alert for the "wide range bar" study? at the moment i am using study to colour all the wide range bars, but i would like t add a simple sound alert to it, but since the study doesnt give me a value when a wide range bar is formed, i dont know how to write the alert. thx for helping |
[2021-03-18 12:38:40] |
Sawtooth - Posts: 4174 |
If you only want an alert sound when the Wide Range Bar study colors a bar, use a formula like this on the Alerts tab: =ID1.SG1>0 where ID1 is the Wide Range Bar study. |
[2021-03-18 13:20:01] |
Great. thank you, it worked.
