Date/Time: Sun, 04 Oct 2026 05:40:18 +0000
Volume Profile Data Extraction to Spreadsheet
View Count: 1940
[2021-03-18 01:30:52]
quin6 - Posts: 22
Hi, I wish to extract a specific type of data from the volume profile and put it into the spread sheet.
I want to extract the TOTAL volume at each price level for a weekly volume profile (1st picture) and put that into the spreadsheet and have it update in real time.
I do not want to have it in the format in the 2nd picture below where there are these weird price ranges with excess columns and the data is sparse. (2nd picture)
I want just the total volume of each bar of the profile updated in real time, that is it.
Is there anyway to do it the way that I want?
Please this will be very helpful, thank you.
Date Time Of Last Edit: 2021-03-18 01:33:20
imageScreenshot 2021-03-17 201731.png / V - Attached On 2021-03-18 01:32:42 UTC - Size: 5.84 KB - 390 views
imageVolumeAtPriceSpreadsheet.png / V - Attached On 2021-03-18 01:32:45 UTC - Size: 19.62 KB - 349 views
[2021-03-18 13:43:14]
If the default functionality for outputting Volume at Price data to a Spreadsheet does not do what you require, then you need to use ACSIL to access this data:
ACSIL Programming Concepts: Accessing Volume at Price Data Per Bar
And output the data to the spreadsheet as you need:
ACSIL Programming Concepts: Direct Programmatic Interaction with Spreadsheet Sheets
