Date/Time: Sun, 27 Sep 2026 21:09:41 +0000
diffrents betwen backtest modis
View Count: 793
[2021-03-17 23:56:00]
Mr.DaxF - Posts: 47
hello dear support i have a question?
you write here: Auto Trade System Back Testing
that the Replay backtest the one is who make the best consistancy! can you confirm it? - i will go sure that i understand it right!
and is here than bether to used this: Chart > Replay chart > Replay chart (control panel) or Trade > AutoTrade system replay BackTest ?
and it is bether to used "accurate trading system backtest mode" ? or "calculate at every tick/trade ( high Cpu usage) ?
what i want to know is only what make the nearest reuslt to real market behavior?
thank you verry much
[2021-03-18 14:21:50]
Yes.
Either way. If you start the Replay manually, just make sure the controls are set appropriately on the Replay control panel.
We definitely do not recommend calculating at every tick. That is very very slow and will cause Sierra Chart to freeze.
[2021-03-18 17:38:22]
Mr.DaxF - Posts: 47
hello, thank you!
--> i have enough power on my PC to handle it. but please tell if there any diffrences AND what is bether from seen results etc... take the technical issues away only from the result side. what is bether?
[2021-03-19 03:07:13]
Mr.DaxF - Posts: 47
Hello, sorry but i need this information as soon as possible!
can anybody from help desk answer my questions? :)
thank you
