Date/Time: Mon, 25 Nov 2024 18:33:15 +0000
Overnight Data missing from ZSK4
View Count: 1132
[2014-03-03 15:31:26] |
RMF2 - Posts: 43 |
I tried to download the historical data/overnight for ZSK4 this morning. There was no data for the overnight session. Is the historical file being updated? |
[2014-03-03 15:58:49] |
RMF2 - Posts: 43 |
I see the price data now. Can the Numbers Bar data be updated, too? |
[2014-03-03 18:20:08] |
This was a problem originating on the OEC side. We will be patching the missing historical data, this evening and also seeing if we can fill in the missing Bid Volume and Ask Volume needed by Numbers Bars. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-03 18:20:38
[2014-03-03 18:40:58] |
Re-download the data for the last two days. The data has been patched with Bid Volume and Ask Volume. Here are the instructions for this: http://www.sierrachart.com/index.php?l=doc/helpdetails2.html#h2.1.2 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-03 18:41:42
