Date/Time: Mon, 24 Feb 2025 18:36:26 +0000
connecting to other real time data exchange
View Count: 555
[2021-03-17 23:22:08]
User861461 - Posts: 4
hello SC!
I would like to check if I want Hong Kong Futures exchange access - i need to activate the real time connection ($25/month) then activate the HKFE exchange ($16/month), is that correct?
Or can I subscribe to exchange with my futures broker (AMP) and the data would feed back to AMP?
Many thanks!
[2021-03-18 14:18:04]
John - SC Support - Posts: 38145
You can get the data from either source, assuming that it is available from your broker.
If you do get it from us, then you have the correct information in terms of using the Sierra Chart Exchange Data Feed and activating the HKFE exchange.
If you get the data from your broker, then there is nothing special you need to do within Sierra Chart. You can get that data from them and continue to use the Denali Exchange Data Feed for the CME Group.
[2021-03-18 14:25:59]
We definitely recommend getting the Hong Kong futures data from the Sierra Chart Exchange Data Feed. Instructions:
[2021-03-18 20:55:34]
Thanks John - are sc looking at sydney futures exchange or osaka futures exchange? As I don't see them on the other exchange list. Many thanks
[2021-03-18 21:11:03]
All we can say is not anytime soon.
