Date/Time: Mon, 24 Feb 2025 15:26:42 +0000
Value area extended
View Count: 684
[2021-03-17 20:04:53]
User499894 - Posts: 47
Hi, is there a way to extend the value area of VbP study in the shape of a band (like if you would draw an extended rectangle confined between the VAH and VAL) and keep the "future intersection" possibility?
[2021-03-17 20:50:30]
John - SC Support - Posts: 38116
Yes, you can do this, although the transition point is going to look a bit odd.
Use the Study Subgraphs Reference study and reference the Value Area High Value and the Value Area Low Value subgraphs. By default the Study Subgraphs Reference create a band. You just have to make sure you put the study in Region 1 and you set the Scale to Automatic.
[2021-03-17 23:13:34]
Great, thanks.
