Date/Time: Mon, 24 Feb 2025 15:26:41 +0000
Amp/CQG opened
View Count: 433
[2021-03-17 17:52:22] |
pigeon - Posts: 5 |
I signed into AMP and payed for service. How do I connect to data via Sierra? Thank you |
[2021-03-17 19:00:04] |
John - SC Support - Posts: 38116 |
We are not sure exactly the question you are asking, so we will answer a couple of possibilities. First, if you are asking how to connect your Sierra Chart to CQG, then you would follow these instructions: CQG Trading Platform Service: Setup Instructions Second, if you are asking for data from us, then we need to know the exchanges for which you want real-time data and whether you need Market Depth data or not. We can then direct you from there. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
