Date/Time: Mon, 24 Feb 2025 15:44:07 +0000
Need: Full CME Group (CME, CBOT, COMEX, NYMEX) + CFE
View Count: 603
[2021-03-17 16:56:24]
User266903 - Posts: 26
I trade only CME products. I want to start trading VX & VXM futures, calendars etc. Also, I am with AMP and plan to transition to a Sierra Data feed + direct Sierra platform subscription etc.
What is the best way to go about it? If I subscribe to Pkg. 10 + CME exchange, I won't get VX right? It seems to be a part of "Sierra Chart Real-Time and Historical Exchange Data Feed", but I don't really want to a) run a separate instance of Sierra, b) subscribe to the second feed for $25 just to be able to trade VX
I need to pay for CFE fee, that is fine. Anyway I can access CFE with Denali feed? Or is there a better workaround?
[2021-03-17 17:49:29]
John - SC Support - Posts: 38117
The Denali Exchange Data Feed only has data for the CME Group and EUREX.
Therefore, to get the data for the CFE, you would need to use the Sierra Chart Exchange Data Feed and activate the CFE exchange. As you note, this would be $25.00 USD per month for the Sierra Chart Exchange Data Feed for 250 symbols and $15.75 USD per month for the CFE exchange. For more information refer to the following:
But you do not need another Sierra Chart instance to get this data. You would be able to get it in the same instance in which you are getting the Denali Exchange Data Feed. Refer to the following:
https://www.sierrachart.com/index.php?page=doc/RealTimeDataFeedsAvailableFromSierraChart.php#UsingBothDenaliExchangeDataFeedAndSierraChartExchangeDataFeed
