Date/Time: Mon, 24 Feb 2025 15:20:54 +0000
Future trading account with TransAct
View Count: 506
[2021-03-17 15:47:00] |
User828648 - Posts: 1 |
Hi support would like to set up my live funded account with TransAct to feed my Sierra Trading and Charting can you help me set it up or send me instructions on setting up my account please.
[2021-03-17 17:19:54] |
John - SC Support - Posts: 38116 |
If you have already setup your account with TransAct, then just go into your Sierra Chart software and select File >> Data/Trade Service Settings and set the Service to TransAct WS. Then select the A button next to the service to select it. You will then get additional fields below the Service to fill out including Username and Password. Fill in the fields in that section according to the information you have from TransAct and then select OK. You should be all set from there. For information on how to interact with the new Sierra Chart windows, refer to the following: Settings Windows Interface And specifically this section for the Service setting: Settings Windows Interface: Item List (Working with Sierra Chart Windows >> Selection Specific Options) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
