Date/Time: Mon, 24 Feb 2025 15:41:15 +0000
Instructions with Broker and Sierra Chart
View Count: 456
[2021-03-17 12:07:11]
User738735 - Posts: 1
Hi all,
I am pretty new to Sierra Chart and I would like to ask a question. So I would like to trade from within sierra chart, for instance, from within the Depth of market. Is that poossible? What brokers do support for such matter.
thank you.
[2021-03-17 15:17:32]
John - SC Support - Posts: 38116
We assume that you are referring to being able to place trades on the Chart/Trading DOM in the Depth of Market area using your pointer. This is supported. Refer to the following for information on setting the specific Order Type based on where and how you click:
Global Trade Settings Windows: Left Click on Buy Column Above Last (Global Settings >> Chart DOM Settings >> Order Types >> Order Types Above/Equal Last for Chart DOM)
Any broker can be used, the broker does not make any difference in terms of being able to place orders on the DOM. Different brokers may have differences in what order types they support. You would need to look at the information for the different trading services by selecting the link for each one in this section:
Supported Data and Trading Services: Supported Services
