Date/Time: Mon, 24 Feb 2025 16:23:18 +0000
QuoteBoard separator and sort
View Count: 605
[2021-03-17 12:01:55]
User664285 - Posts: 11
Hi, how do I add a separator to the quoteboard so I can have two lists. And also how can I manually sort the symbols, doesn't seem to let me move them up/down as I'd like for example by clicking and dragging.
Thanks.
[2021-03-17 15:13:10]
John - SC Support - Posts: 38122
Refer to the following for adding a Separator to the Quote Board:
Getting Quotes: Quote Board Label Rows
To move the position of a symbol you have to change it in the Setting Symbols window. Refer to the following:
Getting Quotes: Setting Symbols
[2021-03-17 15:25:31]
Thanks, unfortunately labels don't seem to work with field sorting. For example if I have a Volume field and click to sort (descending/ascending) the grouping and label disappears. The expected behavior here is that sorting will be done within the group while maintaining the labels in their place. Can that be done? If not can you please consider this as a feature request. Thanks.
[2021-03-18 03:27:45]
User90125 - Posts: 715
At the top of the QuoteBoard, just select Settings >> Sort Within Groups.
