Date/Time: Mon, 24 Feb 2025 15:36:49 +0000
dalayed quotes
View Count: 471
[2021-03-17 08:57:07]
Mariusz Kozak - Posts: 1
Hello, good morning,
My quotes are delayed.
For example, there is 9:56 in Poland right now and on SIERRA CHART i see 8:46 as if there is 1:10h of dalay.
How can i change it?
Regards,
Kamila
[2021-03-17 14:51:24]
John - SC Support - Posts: 38116
You are not setup to receive Real-Time data from us. Are you setup to get Real-Time data from another source?
For testing purposes we recommend using the Delayed Exchange Data Feed. Refer to the following:
If you want to get Real-Time data from us, then refer to the following to get started:
Real-Time Exchange Data Feeds Available From Sierra Chart
