Date/Time: Mon, 24 Feb 2025 15:09:41 +0000
VbP
View Count: 477
[2021-03-17 02:56:02] |
joshtrader - Posts: 501 |
See attached picture. There's data there, and it has volume (see Volume subgraph). Why isn't that data show in the VbP? On that chart, there are only two studies: VbP and Volume. Date Time Of Last Edit: 2021-03-17 02:56:38
[2021-03-17 08:09:08] |
What is the symbol of the chart? That data may be from Interactive Brokers which would definitely affect this.
[2021-03-17 22:05:17] |
The problem here is that the "Exclude Evening data" option is set to Yes. Call me crazy, but when the profile is set to "Visible Bars" I would think that takes precedence over an option about excluding certain sessions. However, I can see how it may be useful. Nonetheless, it is a bit confusing. |
