Date/Time: Mon, 24 Feb 2025 15:21:59 +0000
no free data service enabled
View Count: 451
[2021-03-17 02:27:45] |
JanRasLnd - Posts: 1 |
Dear All I would like for the time being just have the SC 5 and the free data feed, delayed and historical. I can't see that it is activated in my account and hope you can help with that. Many thanks Jan |
[2021-03-17 08:49:59] |
Your Sierra Chart account is active and you have access to this data. However, restart Sierra Chart following these instructions: Sierra Chart - Software Login Instructions: Forced Login And then just follow through the instructions here: Delayed Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-17 08:51:04
